about quad voice coil sub
Old Nov 20, 2006 | 12:42 AM
flyinghigh2k8's Avatar
flyinghigh2k8
Default about quad voice coil sub
Ok I really need help I am getting this 3200rms watt hifonics sub with quad voice coils. http://www.sonicelectronix.com/item_5652.html. It's has quad 2 ohms. Does that mean that each voice coil has 2 ohms making the sub 8 ohms total. If so does this mean that the amp(s) has to come to a total of 8 ohms. (either one 8 ohm amp, two 4 ohm amp, or four 2 ohm amp, or something similair) And if I am correct on this information is this all only true for mono amps. Will it change up everything if I consider 2 channel amps because I will have to bridge them and what not. Thanks alot guys, please help me.
Old Nov 20, 2006 | 12:04 PM
Hawk's Avatar
Hawk
Default RE: about quad voice coil sub
If the sub has 4 (quad) 2 ohm voice coils, than the way you wire those voice coils together will decide your total impedance. If you wire 2 of the voice coils together in series, wire the other 2 voice coils together in series, and then wire the 2 pairs together in parallel, you will have a 2 ohm load.
Another scenario would be to wire all the voice coils in series and then yes, you would have an 8 ohm load.
You could also wire 2 of the voice coils in parallel, then the other pair in parallel, and then the 2 pair together in series and that would also give you a 2 ohm load.
It will depend on the output of them amp as to what configuration you should use.
Just remember, when wiring in series, impedance (R) is calculated using the following equation:
Rtotal = R1 + R2 + R3 + ...
and the calculation for parallel is...
Rtotal = (R1 x R2)/(R1 + R2)
Hope that helps.
FivePointToTheOh
Mar 9, 2020 10:26 PM
Granatelli Sales
Mar 25, 2016 08:01 PM
firehorse02
Nov 16, 2015 11:28 AM
Sixer4Life
Sep 28, 2015 07:05 AM
lmurf60
Sep 24, 2015 10:07 PM
