Help me find 12v ignition wire
My girlfriend has a 2002 V6 Mustang convertible that was recently broken into.
Instead of spending $400 for an alarm, I plan on spending $5.00 for a bright flashing LED that makes it look like it has an alarm.
My alarm in my jeep has a similar LED, and it is WAY obvious that it's not OEM so it should do the trick........or at least help a little.
Here is a link to what I am looking to install:
http://cgi.ebay.com/VARAD-LL101-SUPE...QQcmdZViewItem
Can somebody please direct me to which wire I want to use for the 12V ignition wire which is grounded when the engine is off?
I really don't want to go aroud messing with wires that have ANYTHING to do with the ignition without knowing exactly which one to splice into.
Would an accessory fuse which is turned off while the vehicle is turned off work? Like a radio fuse or something? Thanks.
Thanks for your help.
-Will
-Will
Not sure where the 12 volt constant wire is. No, using the accessory wire or fuse wouldn't work. There would be no power to the led when the ignition is off. You could always run it off of the cigarette lighter wiring or directly to a 12V constant in your fuse box.
Have you looked at the link by any chance?
There are 3 wires.
1 constant 12v - easy
1 ground - easy
1 going to 12v ignition wire that is grounded when vehicle is off
This is what throws me off just a bit.
It's designed to turn on when the vehicle is off, and turn on when the vehicle is off.
I don't think that I should have to mess with an actual ignition wire, and I would think that I could splice it into a power source that is off when the vehicle is off. Unless if I am completely wrong and it's the other way around......
There are 3 wires.
1 ground - easy
Just checked the link, now I see your dilemma. Found this on net if helps:
Item Wire Color Polarity Wire Location
12V yellow & lt. grn/pur Positive (+) ignition harness
Starter white/pink Positive (+) ignition harness
Starter 2 none
Ignition red/lt. green Positive (+) ignition harness
2nd Ignition gray/yellow Positive (+) ignition harness
3rd Ignition none
Accessory black/lt. green Positive (+) ignition harness
Accessory 2 red/black Positive (+) ignition harness
Tachometer [3] [3]
Power Door (Lock)
Wiring Diagram for
[Positive (+)] Door Lock lt. green Positive (+) low in drivers kick or [1]
Power Door (Unlock)
Wiring Diagram for
[Positive (+)] Door Unlock purple Positive (+) low in drivers kick or [1]
Door Trigger [2] Negative (-) [2]
Dome Supervision
Wiring Diagram for
[Positive (+)] Dome black/white Positive (+) drivers kick panel or [1]
Headlights red/yellow Positive (+) light switch
Parklight Positive brown Positive (+) light switch or drivers kick
Parklight Negative white/black Negative (-) [1]
Wipers white & dk. blu/orn Positive (+) wiper motor
Left Front Window
(Up/Down) wht/blk - wht/blk drivers window motor
Right Front Window
(Up/Down) tan/blu - wht/yel drivers kick panel
Left Rear Window
(Up/Down) yel/blu - gry/orn A drivers kick panel
Right Rear Window
(Up/Down) yel/blk - red/blk A drivers kick panel
Trunk/Hatch Pin brown/white Negative (-) drivers kick panel or [1]
Hood Pin none
Trunk/Hatch Release
Wiring Diagram for
[Positive (+)] Trunk/Hatch purple/yellow Positive (+) drivers kick panel
Factory Alarm
(Arm)
Factory Alarm
(Disarm) dk. green/purple Negative (-) drivers kick panel or [1]
Horn yellow/lt. green Negative (-) steering column or [1]
Brake red/lt. green Positive (+) brake switch
Door Motor
(Lock) red/white low in drivers kick or [1]
Door Motor
(Unlock) red/orange low in drivers kick or [1]
Disarm pink/orange GEM module [1]
Disarm No Unlock
Starter 2 none
3rd Ignition none
Tachometer [3] [3]
Power Door (Lock)
Wiring Diagram for
Power Door (Unlock)
Wiring Diagram for
Dome Supervision
Wiring Diagram for
Left Front Window
Right Front Window
Left Rear Window
Right Rear Window
Hood Pin none
Trunk/Hatch Release
Wiring Diagram for
Factory Alarm
(Arm)
Factory Alarm
Door Motor
Door Motor
Disarm No Unlock
A good place to ask is the follwoing forum: http://www.caraudio.com/forum/
They will definitely would be willing and able to help you out. Am a member there myself.
