Amp Wiring
Old Dec 10, 2006 | 09:46 PM
usfmustang03's Avatar
usfmustang03
Default Amp Wiring
Does anyone know if the signal wire that reaches from the amp to the back of your cd player have to be a certain size? My power keeps cutting out on me when i turn the volume up to high, is that wire just not large enough? Its very thin and actually attatched to my Rockford Fosgate wires, it came like that in the wiring kit i bought.
Old Dec 10, 2006 | 10:16 PM
Leeiswho2b's Avatar
Leeiswho2b
Default RE: Amp Wiring
That is the remote wire. It should be just fine. I would check all of you grounding locations for good grounds (needs to be grounded to bare metal). Also check your voltage when it cuts out. Some amps are very temperamental with voltage going too low and shut off.
Old Dec 13, 2006 | 06:33 PM
PennState's Avatar
PennState
yeah i have the same problem!!
now my head unit wont even turn on!!
Old Dec 13, 2006 | 09:34 PM
blownbayou's Avatar
blownbayou
ORIGINAL: usfmustang03
Sounds like you have your amp bridged into an ohm load that your speakers cannot handle...
Just a thought
Later
Old Dec 14, 2006 | 04:51 AM
97tunedmustang's Avatar
97tunedmustang
ORIGINAL: blownbayou
Just a thought
Later
Thats what i'm thinking. If not that maybe your alternators going out. or your power wire is too small. i would need to know specifics of your wiring though to really say.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
