Hooking Up An Amp To Factory...
Old Jan 3, 2007 | 04:25 PM
06z28eater's Avatar
06z28eater
Default Hooking Up An Amp To Factory...
whats up guys? im just wondering what it takes to hook an amp, kicker, rf,etc...to the factory 6 disc changer in my 03, someone said i could buy some sort of splitter or something, i havent taken out the headunit to look behind it, im trying to decide if i wanna hook up the 7 inch indash dvd player i got or just put it into my explorer, but id like maybe 1 10 or 1 12 in the stang, anyone?
Old Jan 4, 2007 | 01:33 AM
Riggs007's Avatar
Riggs007
Default RE: Hooking Up An Amp To Factory...
a splitter will only run you about 40-50 bucks. You cut into a back speaker and run it off there. My buddy used one, not bad if you want to keep the stock look up front. But your better off switching the head unit.
Old Jan 4, 2007 | 03:31 AM
06z28eater's Avatar
06z28eater
a buddy of mine told me that 1 of my boys changed out his headunit for an alpine unit, and when he did he had to bypass the factory amp and the only speakers he could run were the front door speakers(all 4 of them) ... is there anything you can pick up to keep the factory amp and all the speakers? i love the way it sounds inside, nice crisp sound there
Old Jan 4, 2007 | 01:34 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
Go get a high/low converter for like 10 bucks. You have to splice in the rear speaker wires and run 1 ground to it. Mount it up on the rear rack. Then the RCA cables will run from the converter to the amp. I had this set up with my 02 GT with the mach 460. Its nice cause the stock head unit will still control the bass.
Old Jan 4, 2007 | 06:30 PM
06z28eater's Avatar
06z28eater
ive never paid attention to the high low converter but im sure i can pick it up at any radio place right? and thanks thats what ill do
Old Jan 4, 2007 | 06:51 PM
PROMETHEUS PRIME
Yeah I went into my local stereo shop when Ibought myamp and they gave it to me for free. They usually go for around 10-15$. Just make sure you adjust the levels on it. My friend got one that had them set all the way off and he thought the converter was bad. Good luck though.
Old Jan 4, 2007 | 07:11 PM
PennState's Avatar
PennState
yeah all u need is a line out converter!
88 orangepeel notch
Oct 5, 2015 09:03 AM
breaking
Oct 2, 2015 01:27 PM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
daytooday
Sep 20, 2015 10:55 AM
cbird1177711
Sep 3, 2015 08:43 PM
