12 volt system
Old Jan 13, 2007 | 04:59 PM
5speedstang's Avatar
5speedstang
Default 12 volt system
how many 12 volt out puts can you put on one12 volt imput with out blowing anything. i just got some of my system done and needed something else so i went and purchased 12 inch red neon tubes to lay between the red suede and the black leather trim panel. think i will be fine hooking up all four tubes to one 12 volt line?
Old Jan 13, 2007 | 07:12 PM
ttocs's Avatar
ttocs
Default RE: 12 volt system
you will be better off gettinga relay to drive these seperate lights to do it right. A relay is an electronic switch that will allow the voltage needed to be used when needed, off when not. A relay with the correct hrns should only be $4-10 at a local auto parts store as allow for the correct connection.
If you add one, maybe two you would be ok but still really need to use the relay. I can walk you through it if you like....
Old Jan 13, 2007 | 07:48 PM
5speedstang
go for it walk me threw. im goin tonight to buy a relay. i hope this works like you say it will. its pissing meoff.
Old Jan 14, 2007 | 11:06 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
ttocs is correct. The problem you are going to get into (if not already) is excessive current (amp draw) from a single source. There is not so much a limit to how many items you can "run" from a single source, but rather the total amperage draw of all items combined. One has to take into consideration the TOTAL aperage draw of ALL items connected to power source as well as wire guage and the fuse that is going to be used. The beauty of using a relay is the displayed in the following pic.
#86 connection will come from the "trigger" line. This will go to the switch that you want to use to turn all
the new equip on with (< my english teacher would not be impressed with my syntax there [&o])
#85 Pretty obvious, run connection straight to the body of car
#87a In your case, this line will probably be left un-used
#87 This connection will go to the power source that is fused and properly guaged to supply ALL the
power for the new items you are connecting (to battery)
#30 This will connect to ALL wires going to the new equipment.
There are several different ways to connect a relay, and are a fantastic item. One of the beauties of this baby is the ability to install even the smallest switch or have a dashlight"control" eventhe most high current of items.
Jazzer
[IMG]local://upfiles/39838/AA5704CF3E854379BEC50769C5B9A975.jpg[/IMG]
Old Jan 14, 2007 | 02:57 PM
5speedstang
i got it, its all good and working. i didnt use a relay, i just tapped the cig lighter in the center council. works just fine. i had a short in the wire i was using.
Old Jan 15, 2007 | 12:20 PM
Jazzer The Cat
Retired Moderator
Your welcome
bradleyb
Nov 27, 2015 07:50 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
