best 12V source/ factory amp
Old Jan 14, 2007 | 09:20 PM
jtstudley's Avatar
jtstudley
Default best 12V source/ factory amp
Hey I have two questions. i am going to hardwire my GPS and Radar Detector and I am wondering where the best 12V place would be wiht out causing power issues, I already have a XM radio hardwired but the install looks pretty shotty and I might redo that too.
Next, I am installing a radio for a friend, with my other friend. He thinks that it is okay to leave the stock amps on the system, (His stereo sounds like ****, btw). For some reason I think that is bad (based on nothing but side comments). The system we are installing will have a new amp for the speakers, I assume it is best to take outh the stock amps right. (My friend thinks that they will only just add more power) Who is right
Old Jan 14, 2007 | 09:35 PM
ttocs's Avatar
ttocs
Default RE: best 12V source/ factory amp
page 2 of my sig shows how I kept the stock speakers and amp. If you do it right you can suprise yourself but it takes some tweeking. I used a line driver on my alpine sub output to allow me to adjust the bass to the system independendtly from the volume to help out, as well as some x-overs for the front speakers which is a necessity.
As for hardwiring, cig lighters are always popular and there is also a hrns below the consol for most mustangs that has a switched and a constant for the convertable(if a hard top) that is unused.
Old Jan 14, 2007 | 10:45 PM
seight311's Avatar
seight311
Best Place? From your battery, with a fuse on it. Easiest, you could use the cigarette lighter, or the same one your radio uses.
Old Jan 17, 2007 | 06:45 PM
jtstudley's Avatar
jtstudley
Alright, but the system already includes aftermarket amp, speakers, etc. There would be no benefit to leave the stock amp in the circuit right?
HU-new amp-new speakers is better than,
HU-stock amp-new amp-speakers
correct?
Old Jan 17, 2007 | 06:50 PM
stangdude81's Avatar
stangdude81
dunno on the stereo, I haven't been to far into that part of this car yet. As far as the radar detector, If you don't have the alarm, pull down the map light assembly and tap into the 12v wires there. The 12V is always hot there, the ground is what floats to light the map/dome lights. Probably just ground to the sheet metal up there and you're set. Mount the detector below the mirror and you're set, pretty clean install.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
daytooday
Sep 20, 2015 10:55 AM
cbird1177711
Sep 3, 2015 08:43 PM
