dual subs
Old Jan 16, 2007 | 11:16 AM
ridemx129's Avatar
ridemx129
Default dual subs
im installing a pair of 12" duals with the 600 watt dual amp and i got it all wired up but when the volum is very low they work but as soon as you turn it up or crank the base the protect light comes on
its in a 2002 honda civiv ex.
any explenations?
Old Jan 16, 2007 | 12:46 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: dual subs
Sounds like low impedence to me. Maybe PReal can assist...
Jazzer
Old Jan 16, 2007 | 03:05 PM
PReal's Avatar
PReal
I need specs of subs and amp. I would bet your dropping your impedence to low as stated above.
Old Jan 16, 2007 | 03:08 PM
00raging stang's Avatar
00raging stang
600 watts is not alot for 2 12" subs maybe a bigger amp, i have a 1000 watt amp for my 2 12" and im gettin another 560 rockford amp
Old Jan 16, 2007 | 03:17 PM
PReal's Avatar
PReal
600 is plenty for 2 12's. It all depends on the equipment and installation.
Old Jan 16, 2007 | 05:03 PM
MicNificentX13's Avatar
MicNificentX13
you got the 12 inch duals from best buy i got those in mine, they are beasts for the price~!
Old Jan 16, 2007 | 05:15 PM
97tunedmustang's Avatar
97tunedmustang
If i had to guess im thinkin you have the connections between the subs and amp wired improperly and causing an ohmload to great for the amp to handle.
Old Jan 16, 2007 | 08:54 PM
PReal's Avatar
PReal
ORIGINAL: 97tunedmustang
Actually it is quite opposite.
The lower the impedence the larger the power output from the amp. If you are exceeding the power output of the amp through low impedence, most amps will shut off due to a thermal switch. The extra power caused an increased amount of heat that cannot be dissipated by the heatsink and therefore can damage your amp.
Duals are never a beast for the price. You could have bought much better over the web.
Old Jan 16, 2007 | 09:03 PM
00raging stang
ORIGINAL: PReal
yeh, it was just a guess
Old Jan 16, 2007 | 09:04 PM
P Zero's Avatar
P Zero
One of the subs is wired backwards. Check your outputs I guarantee one had the - on where the + is supposed to be. Itll work at SUPER low volumes, but as soon as you turn it up it cuts out. Ive seen a bunch of times. I used to work at a sound shop where kids would bring their cars in with everything installed and they couldnt figure out why it either sounded like absolute **** or 1 sub worked the other didnt, etc, etc. Connections were on backwards.
-P.
