dual subs
Old Jan 16, 2007 | 10:14 PM
PennState's Avatar
PennState
Default RE: dual subs
ORIGINAL: PReal
600 is plenty for 2 12's. It all depends on the equipment and installation.
+1
Old Jan 16, 2007 | 10:15 PM
PennState's Avatar
PennState
ORIGINAL: MicNificentX13
you got the 12 inch duals from best buy i got those in mine, they are beasts for the price~!
haha i used to work their
and they use to come in all the time for repair..
for the price their not bad
but wont last u too long..
Old Jan 17, 2007 | 02:18 AM
ttocs's Avatar
ttocs
two subs being out of phase would result in low/no sound while they were moving like all heck. For every inch on speaker moves out, the other moves in and the two cancel each other. This should result in a low impedence light comming on, the amp would never know the difference
ORIGINAL: P Zero
One of the subs is wired backwards. Check your outputs I guarantee one had the - on where the + is supposed to be. Itll work at SUPER low volumes, but as soon as you turn it up it cuts out. Ive seen a bunch of times. I used to work at a sound shop where kids would bring their cars in with everything installed and they couldnt figure out why it either sounded like absolute **** or 1 sub worked the other didnt, etc, etc. Connections were on backwards.
-P.
Old Jan 17, 2007 | 12:36 PM
PReal's Avatar
PReal
I have wired speakers out of phase and the amp will not see a lower impedence. You are only changing the current direction which based on F=M x B ( thats a physics equation kids) if the direction of current (B) is reversed the cross product of that and the magnetic field will result in a force in the opposite direction.
Simply put, your speakers are not wired in the correct series/parrallel combination. They could be wired out of phase as well, but that should have no effect on impedence.
folivier
Oct 2, 2015 05:34 AM
Sixer4Life
Sep 29, 2015 07:03 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
