Speaker install
Old Oct 3, 2004 | 09:59 PM
goatman's Avatar
goatman
Default Speaker install
I just bought an '04 GT and want to replace the speakers myself. Any tips or tricks on getting the door panels off and how to access the rear speakers? THANKS!
Old Oct 14, 2004 | 07:19 AM
Acewelder99's Avatar
Acewelder99
Default RE: Speaker install
on the door panel take out all screws and start pushing upward on the door and it should lift up a little the pull out. Rear take off the head rest pads the the carpet piece over speakers. bolts should be along sides and bottom. Taking speakers out of rear your gona need a spubby screw driver very tight
Old Oct 15, 2004 | 03:24 PM
goatman's Avatar
goatman
Thanks for the help - did the front speakers - no problem, will do the rear speakers this weekend. Do you think it's worth cutting the carpet out to get better sound?
Old Oct 16, 2004 | 10:21 AM
CrazyCarAudio's Avatar
CrazyCarAudio
Cutting the carpet out really wont effect the sound too much. If you want better sound, try putting an amplifier to the speakers, about 200 watts would give you a nice clean and loud sound.
Old Oct 19, 2004 | 11:03 PM
Acewelder99
did you have fun trying to get those screws out of the rear speakers?
Old Oct 19, 2004 | 11:15 PM
goatman's Avatar
goatman
Actually, the hardest part was getting the damn carpet thing off. I had a 90 degree screwdriver that is only about 1.5 inches long, so I used that to loosen them. Then I just took the bit out and did it by hand, so not that bad.
Thanks for the help, would have never figured out how to do it!
Old Oct 20, 2004 | 07:48 PM
Acewelder99
no problem ! glad to have helped
mtgldr
Feb 3, 2024 09:00 PM
unit91
Sep 15, 2015 09:53 AM
Doogie65
Sep 6, 2015 02:55 PM
TimeLord101
Sep 4, 2015 09:27 AM
