Need help...i'm blowing fuses
Old Jan 21, 2007 | 05:14 AM
91blackmustanggt's Avatar
91blackmustanggt
Default Need help...i'm blowing fuses
I bought a Sony XS-L123P5B subwoofer today and I went to hook it up to my Sony XM-504Z amp and it melted the fuse. The fuse is a 60 amp. I don't know much about this stuff so some suggestions would help.
Old Jan 21, 2007 | 05:55 AM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
Default RE: Need help...i'm blowing fuses
250 amp ftw
Try an 80 amp, if it's blowing, make sure you have your wiring correct.
Old Jan 21, 2007 | 12:44 PM
PennState's Avatar
PennState
yeah make sure your not wiring the ground to the remote or the other way around! that deff can cause you to blow a fuse!
Old Jan 21, 2007 | 04:02 PM
seight311's Avatar
seight311
Wire may be grounding out somewhere, any wiring that is. Or worst case scenario, your amps blown. Wouldn't be too much of a surprise if you know what I mean.
Old Jan 22, 2007 | 12:20 AM
PReal's Avatar
PReal
Also check to make sure the positive and negative wires aren't reversed.
Old Jan 22, 2007 | 02:39 AM
ttocs's Avatar
ttocs
NEVER try a bigger fuse. That will only make the problem worse if you have a problem.
How are you wiring a single voice coil, single sub into a 4 channel amp and what else is that amp driving?
Old Jan 22, 2007 | 03:08 AM
Hisss04Cobra
says hiththth
ORIGINAL: ttocs
I went from a 40 amp to a 250 and fixed my problem. Maybe your experience isn't always correct.
Old Jan 22, 2007 | 10:31 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
ORIGINAL: Hisss04Cobra
ORIGINAL: ttocs
You installed a 250 amp fuse?!?!?!?!?!?! I am in agreement with ttocs. Something else is wrong. A fuse that large is for like 3500 watt system. Please do a little more research on the prob, you missed something.
Jazzer
Old Jan 22, 2007 | 12:51 PM
PReal's Avatar
PReal
Sometimes a bigger fuse is the answer, but I would try everything else first.
Old Jan 22, 2007 | 08:27 PM
Jazzer The Cat
Retired Moderator
In my travels today, I started thinking about this a little. I never actually looked at the amp that was in use (doesn't change the wattage demand that would call for a 250 amp fuse) but have looked it up now. Looking at a 200 watt or so amp, so should need a 20 amp fuse max. Why the fuse doesn't blow now, is a mystery without more info, but can say for sure that 250 amp fuse is INCORRECT for this amount of power. Sorry to be a H.A. but electrical issues should not be messed with. Just b/c it is working, doesn't make it right.
The Jazzer
