aftermarket headunit on MACH system
Old Jan 21, 2007 | 06:01 AM
02GT87's Avatar
02GT87
Default aftermarket headunit on MACH system
i have a quick question, i have read threads saying that the factory amps will not work with an aftermarket headunit unless rewiring is done all over..i was a victim..hahah well my question is..will this solve my problem of not getting any mids and lows out of my stock speakers?
http://cgi.ebay.com/ebaymotors/00-03...spagenameZWDVW
Old Jan 21, 2007 | 11:44 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: aftermarket headunit on MACH system
That little harness is just an adapter to give you bare wires and RCA plugs to connect your new head unit. Techincally, you don't HAVE to use one, but sure makes is a lot easier . You should also be able to pick one up at a local stereo shoppe. I would recommend doing so, as these pepes do this all the time and can give you some pointers as well as adapter plate so new deck fits dash well. I just changed my '02 head unit a few weeks back and was a piece of apple pie, with whipped cream (low fat of course, as eI am watching my figure) and a cherry on top.
The Jazzer
Old Jan 21, 2007 | 12:43 PM
PennState's Avatar
PennState
thats a lot for that harnass
go to bestbuy or walmart
its like under 20 bucks
Old Jan 23, 2007 | 12:28 AM
02GT87's Avatar
02GT87
yeah i found a cheaper one on a different site.. for 20 bucks its on its way well the indash is already but i think the stereo shop just custom wired it with another harness hoping this will fix my problem. so what you guys are saying is with this harness i should be stillable to use my factory amps?
Old Jan 23, 2007 | 01:43 AM
ttocs's Avatar
ttocs
check out page 2 of my sig and it shows how to integrate into the mach, be happy to answer questions.....
The lack of mids and lows is because of this although make sure your amp turn on and remote turn on are connected to the deck(blue and blue with white). If they are not then your amps are not on, neither are your speakers/subs. It is also helpfull to add some capacitors to the tweeters up front as they blow easily with little bass........
Old Jan 23, 2007 | 05:48 PM
Taco2004's Avatar
Taco2004
Here ya go man:
http://www.partsexpress.com/pe/pshow...TOKEN=48852717
http://www.tune-town.com/Cars/stuff/...rd_Mustang.htm
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sixer4Life
Sep 29, 2015 07:03 PM
Sep 24, 2015 09:18 PM
