Installing subwoofer and amp with mach
anybody here install just a sub and amp onto their mach system? i am looking into doing it and found the how-to at MustangWorld . com but am not exactly sure on some of the things that it says. I have no clue how to tell if an amplifier has signal sense. I'm getting a kac 7202 kenwood amp. any help is greatly appreciated.
I see that amp will accept speaker level inputs but I do not see a signal sence. All that means is you will need to run a wire to the amp turn on, which is located on the amp and I think is in the instructions. Worst case scenario you will need to run a wire to a +12v switched accesory.
