Speaker Box
Old Jan 24, 2007 | 05:54 PM
jmsp0610's Avatar
jmsp0610
Default Speaker Box
Does anybody have any dimensions for a speaker box for a 87 coupe. I want to put 3 10s in it. I'm gonna build it myself i just need some dimensions
Old Jan 24, 2007 | 09:34 PM
ttocs's Avatar
ttocs
Default RE: Speaker Box
that would depend on the speaker, not the car.......
Old Jan 25, 2007 | 01:22 AM
PReal's Avatar
PReal
It depends on your space in the car and how much room your willingto give up as well.
Old Jan 25, 2007 | 11:40 AM
billyam87's Avatar
billyam87
Typically going with a sealed enclosure you are looking at .70-1 cubic feet per sub, this varies from manufacturer to manufacturer. I have an 1993 LX notch and have my sub upards firing (12" L5). With in the technical range you adjust the box size to your preferance in music.
Old Jan 25, 2007 | 01:31 PM
xxX Hefty Xxx's Avatar
xxX Hefty Xxx
Honestly I see no logic behind having 3 10's. I think you'll be better with 2 10's and a 12 or just two 10's. Even 1 10 and a 12 would be better if you push more power because you can hit a better bass range. And use fiberglass, looks better then a box.
Old Jan 25, 2007 | 10:12 PM
ttocs's Avatar
ttocs
depends on the 10's. If you get a 6 ohm 10" you can wire all 3 to a 2 ohm load on a mono amp.
Old Jan 25, 2007 | 11:23 PM
PReal's Avatar
PReal
ORIGINAL: xxX Hefty Xxx
I'm sorry, but define better bass range. Also, what is your reasoning behind using woofers of different sizes and how do sub sizes relate to "power push."
I agree that fiberglass looks better.
baddog671
Jul 26, 2016 01:20 PM
daltron
Apr 28, 2016 08:10 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
