yet another mach 460 question.but different
Old Feb 3, 2007 | 11:53 PM
ohthreeGT's Avatar
ohthreeGT
Default yet another mach 460 question.but different
im literally in the middle of wiring up the harness i got to swap out the 6disc for an aftermarket deck.
i bought the Metra 70-5700 wire harness which is supposed to be for the mach460/1000
the only thing im stuck on is the AMP GROUND wires. there are 2 in the 8 pin connector and 1 on the 16 pin connector
do those go together to each other since the radio only has the AMP + but no GRD coming out of it?
also just to double check myself. the 8 pin connector wire get wired with the matching ones from the 16 pin and they go to the radio harness..right?
Old Feb 4, 2007 | 12:52 AM
ohthreeGT's Avatar
ohthreeGT
Default RE: yet another mach 460 question.but different
well i hooked them together and everything turned on and worked. the fade/bal was all correct
BUUUT... everything sounded like complete *** and when your turned the radio off there was a loud thump sound coming from the rears.
is this from an installation error or is the mach 460 just that incopatible with aftermarket decks?
Old Feb 5, 2007 | 11:30 PM
ttocs's Avatar
ttocs
sorry, didn't see this. Describe "***" a little better and I will help ya. The turn on and off thump is normal and while annoying does not hurt anything. Page 2 of my sig shows how I did my 94 with a mach.
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
