front two speakers arent working??
Old Feb 8, 2007 | 09:58 PM
ttocs's Avatar
ttocs
Default RE: front two speakers arent working??
there is no way to swith the amps on a mach system that I know of.
I do not know where the fuses are and would need to look in the manual to find out, the same as you do. Anytime i suspece a bad fuse though I check EVERY fuse(under the dash and under the hood) as circuits are often looped through different circuits that you would not suspect.
Does the rear subs work? Any bass at all?
Old Feb 8, 2007 | 11:48 PM
nofear2606's Avatar
nofear2606
zero bass what so ever. i have checked all the fuses under the dash, i didnt think to check the ones under the hood
Old Feb 9, 2007 | 10:42 AM
ttocs's Avatar
ttocs
What about the rear subs? Is there any bass?
Old Feb 9, 2007 | 04:09 PM
nofear2606's Avatar
nofear2606
there is zero bass
Old Jun 1, 2007 | 08:48 PM
thors_1's Avatar
thors_1
I have the same trouble with mine,=no bass at all.Ibought 2 used amps and nothing changed at all, same thing.no bass. any more ideas guys?
drfister
May 3, 2018 10:38 PM
67LimeCoupe
Nov 25, 2015 08:55 PM
kdryan
Aug 26, 2015 05:54 AM
69FB
Aug 18, 2015 08:50 PM
dseg
AmericanMuscle.com
Aug 10, 2015 03:29 PM
