Just need one more thing!
Where am i hooking up the line out converter for my subwoofer and amp? I have a convertible and am clueless as to where the data cable is. I also heard you can tap into speaker wires, but will that sound as good? So lost with this part..
Well for best signal you should probably tap into one of the rear amps... in the 03 verttheyare in the back of the trunk behind the sheilding (remove 3 clips that are seem directly infront of you when opening the trunk). I believe you must tap the signal from the back of the stock amp. I would like to tell you the wires to tap however its been a while since i did this. this is the easiest place to tap in a vert because there is basically no wire routeing accept remote and ignition. Dont be like me and get an aftermarket h/u a month after, if your planning on h/u just wait on the subs.
KingRando
Oct 2, 2015 08:06 AM
treesloth
Sep 28, 2015 07:03 AM
