Which amp??
Which ampshould i buyif i get a tc-2000 (800w rms) or a tc-3000 (1000w rms) Ive pretty much decided on on of these two as ive heard good things and theyre priced pretty good. What amp do i need for these? Im only getting one 12". The website is www.tcsounds.com Thanks alot guys, Eric
the tc2000(800W) comes in single 4ohm and duel 4ohm voice coil.
The tc3000 comes in quad 2ohm voice coil. Which setup would be best and what amp would i need? Thanks sorry for such a general question
im not really sure yet im not lookin to go too crazy but i want quality stuff. What brand would you recommend. And would i need 1000w rms if i set the amp to be 2ohm instead of 4ohm>
That is not how it works.....
you will wire your dual 4 ohm sub in parrallel which gives you 2 ohms. Your amp will need to be two ohm stable and produce around 1000 watts rms.
http://ikesound.com/product-product_id/4368
http://www.woofersetc.com/index.cfm?...roduct_ID=2697
http://www.woofersetc.com/index.cfm?...Product_ID=284
http://www.woofersetc.com/index.cfm?...roduct_ID=3193
http://www.woofersetc.com/index.cfm?...Product_ID=595
http://www.woofersetc.com/index.cfm?...roduct_ID=4974
There are some options for you. Since you didn't state a budget, check out the last one on the list.
Hifonics are OK. I have had one catch on fire due to quality control problems, but that is why you get a warranty.
Actually look into the Elemental designs 9.1. It is a great amp that would be PERFECT for your application.
http://www.edesignaudio.com/edv2/pro...products_id=44
breaking
Oct 2, 2015 01:27 PM
