Headunit / Dash Illumination Help!
Old Mar 5, 2007 | 01:18 PM
KartR31487's Avatar
KartR31487
Default Headunit / Dash Illumination Help!
I took out my factory headunit a long time ago, and replaced it myself with an aftermarket. Yesterday, I replaced that aftermarket. Everthing works except my dash lights.
The head unit hasa Orange w/white Stripe that is suppose to be connected to the Illumination wire. The wire harness has a solid orange illumination wire, and a orange w/black stripe Negative Dimmer wire. What needs to go where to make my dash lights work?
The solid orange in the wire harness is what needs power. I have it temporary hooked up to the red 12v accessory power supply, so it turns off when I turn my car off. But that way, I cant dim my dash, and plus its not how its meant to be set up.
Thanks in advance!
Old Mar 5, 2007 | 01:55 PM
ttocs's Avatar
ttocs
Default RE: Headunit / Dash Illumination Help!
sounds like you blew a fuse. Check all of the fuses and make sure the orange wires you are not using are capped off properly.
Old Mar 5, 2007 | 02:09 PM
KartR31487's Avatar
KartR31487
I did find a blown fuse.
What am I suppose to hook up the Negative Dimmer wire to? And the Illumination wire? (Both of these on the ford wire harness)
The only thing I have on the headunit is Illumination.
Wheres the dimmer wire go? Ground?
Old Mar 5, 2007 | 07:16 PM
ttocs's Avatar
ttocs
hook up the illumination wires from the hrns from the deck, just insulate the dimmer wires.
Old Mar 6, 2007 | 12:26 AM
KartR31487's Avatar
KartR31487
Changed out the fuse, works fine now. I guess it got shorted out without me realizing. Thanks.
lincolnshibuya
Oct 6, 2015 08:45 AM
Urambo Tauro
Oct 5, 2015 09:37 PM
breaking
Oct 2, 2015 01:27 PM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
accarter
Sep 21, 2015 11:56 PM
