Has anyone done this!?
Old Mar 13, 2007 | 08:23 AM
Scotty07's Avatar
Scotty07
Default Has anyone done this!?
My 07 GT with Shaker 500 has a factory Sirius satelliteradio installed. I want to switch to a Clarion H/U that is "satellite radio ready". The H/U is offered through Crutchfield and comes with the wiring harness and install kit. In talking with the Crutchfield sales person he said I need to buy a Sirius Tuner specifically designed to interface with the Clarion unit. Can't I simply install the new Clarion H/U with the supplied wiring harness adapter and have the already installed Sirius satellite work? Or do I really need to install the tuner that is shown for the Clarion H/U? I was hoping to just install the new H/U and have the Sirius work without installing anything else.
Thanks in advance
Old Mar 13, 2007 | 10:58 AM
nick_svs's Avatar
nick_svs
Default RE: Has anyone done this!?
I can't help you, but this is something that I'll be dealing with pretty soon, too.
I just chimed in because one potential problem you'll have is that each satellite radio unit is unique. If you're still on the 6 month free subscription, then you might have trouble getting that transferred to a new receiver.
Like I said, I haven't spent a lot of time on this, so I don't know. Also, if you're out of the free subscription anyway, then moot point. I just thought I'd bring it up as a question to ask somebody who knows more than me.
Good luck! Let me know how it turns out. I'd just be happy if I could use the factory satellite antenna (which I suspect I can).
Old Mar 13, 2007 | 05:17 PM
Scotty07's Avatar
Scotty07
My Sirius has been shutting off intermitantly since new. H/U checked out fine, even replaced with new unit. Still does it. Must be between the antenna mast and the Sirius tuner.
I am pretty much convinced I will go with a Clarion H/U. I prefer XM's programming over Sirius for what I listen to (I have both and am looking to drop one subscription). I should THINK I would be able to use the Sirius antenna...
I know the door subs have separate amps. Are the rear deck speakers and the 5 x 7 door speakers amp'd through the H/U or through an outboard amp? The Clarion H/U I am looking at going to lists 20 watts RMS and 50 watts peak per channel. Figure that would be enough to drive those factory speakers.
Old Mar 15, 2007 | 04:40 PM
pbguns's Avatar
pbguns
yes you have to buy the sirius interface for the clarion h/u and install it with the radio this will plug in the back and will allow you to controll ur sirius with the h/u
Old Oct 10, 2007 | 12:04 PM
2K7AlloyVert's Avatar
2K7AlloyVert
Have you been able to find out how to use the factory sirius antenna? I have a pioneer HU with the pioneer sirius tuner and cannot find out anywhere how to use the factory antenna.
HELP!
Old Oct 10, 2007 | 01:13 PM
ttocs's Avatar
ttocs
Try the installer forum on carsound.com for the factory antenna. There use to be alot of good info there not long ago.
Yes you will need a clarion sirius unit to go with the new dash unit.
Old Oct 10, 2007 | 03:23 PM
CLOCKWO12K's Avatar
CLOCKWO12K
yes you can use the factory antenna.
