WTF
Old Mar 18, 2007 | 03:23 PM
PReal's Avatar
PReal
Default RE: WTF
Your RCA's still might be next to a high current source. You still might consider moving around your RCA to see if you have a power wire for something like your fuel pump running next to them.
Another idea would be how you can any extra rca cable. In general you need to run the extra in loops.
Old Mar 19, 2007 | 04:23 AM
01vertcobra's Avatar
01vertcobra
Default RE: WTF
Does the humming frequency change when you rev your motor? If so, its alternator whine and you have one of three things. (1) Bad RCA's (2) RCA's running next to power wires (3) A common ground with your alternator. Where do you have it grounded anyway and what side of the car are you running your RCA wires?
Old Mar 19, 2007 | 04:56 AM
gyea's Avatar
gyea
Default RE: WTF
yes it does get louder when accelerating the rca wire is run down the passenger side and the ampis grounded in the trunk toa random bolt... (I grinded the spot to make sure of a good connection)
Old Mar 19, 2007 | 09:50 AM
Insanestang's Avatar
Insanestang
Default RE: WTF
Make sure the bolt u used as the ground is actually into the frame of the car. your bolt could not be grounding correctly.
Old Mar 19, 2007 | 02:19 PM
PReal's Avatar
PReal
Default RE: WTF
If it oscillates with acceleration it is more then likely interference with your rca cables.
Old Mar 19, 2007 | 02:26 PM
ttocs's Avatar
ttocs
Default RE: WTF
disconnect the rca's from the deck and see if the noise is still there. If it is then it is behind the radio in the rca's or amp, if it stops then you need to check your deck.
Old Mar 19, 2007 | 06:07 PM
gyea's Avatar
gyea
Default RE: WTF
yeah they dont hum unplugged ill buy a new cable this weekend
Old Mar 20, 2007 | 02:36 AM
01vertcobra
Default RE: WTF
If that doesn't work, ground your ground wire from your deck somewhere else. Sometimes that will cure it right up.
Old Mar 20, 2007 | 03:49 PM
ttocs's Avatar
ttocs
Default RE: WTF
if the noise stops with teh rca's disconnnected from the deck your noise could very well be comming from the deck. Try running a quick set of cables above the carpet and see if it stops.
ORIGINAL: gyea
xdef00
Feb 27, 2004 03:18 AM
