Correct Wiring harness?
Old Mar 23, 2007 | 03:45 PM
seight311's Avatar
seight311
Default RE: Correct Wiring harness?
If you add that amp and a decent sub you'll barely hear your Mach system.
https://mustangforums.com/m_2678530/tm.htm
It's almost exactly halfway down in this thread look for the big red wirting where it says, how do I hook up my Mach 460 to my new headunit.
Old Mar 23, 2007 | 04:38 PM
Insanestang's Avatar
Insanestang
ightt thanks
Old Mar 27, 2007 | 11:20 AM
lenny23's Avatar
lenny23
Does the wiring harness for the 2001 GT Mach 460 have theRCA plugs for the back of the radioon it too? TheharnessI just bought doesn't andI am having a horrible time hooking it up. I thinkI am going to return it and buy one from the site above. Sorry to jump in your thread butI wanted to refernce the picture above.
Old Mar 27, 2007 | 11:47 AM
lenny23's Avatar
lenny23
I just looked on cardomain for the 2001 harness. The harness on cardomain and the one I bought by metra are quite different looking. It doesn't have RCA jacks though. I am going to return the metra and buy the one on cardomain, it looks likebetter quality. Guess I answered my own question. Thanks anyway.
Old Mar 27, 2007 | 08:32 PM
lenny23's Avatar
lenny23
Suprisingly enough I am stilll alittle confused. Every site has a different picture of the harness. Can the 2001 GT w/ Mach 460 use a harness that has RCA jacks?
Old Mar 28, 2007 | 01:15 AM
seight311's Avatar
seight311
The one I posted right? And yes as long as it's a 460 system and your head unit has front and rear outputs.
Old Mar 28, 2007 | 02:35 PM
lenny23's Avatar
lenny23
Yes, I was talking about the harness you posted in the information post. I am going to pick up the harness today hopefully. Thanks for your help.
Old Mar 29, 2007 | 04:05 AM
seight311's Avatar
seight311
Not a problem, let me know how it goes! Or if you have any other problems.
Old Mar 29, 2007 | 09:12 AM
Insanestang
Ightt now im getting a little confused again. Iknow i need the harness you posted earlier. But dont i need to get the power harness and the speaker harnesses? does one of the plugs from the factory HU plug into the amp that is in the dash? If it does do i need to use that amp anymore? I just need to know what exactly the other two harnesses are that i need.
Old Mar 29, 2007 | 07:08 PM
seight311's Avatar
seight311
When you get that harness that has he rca plugs on it you no longer need a harness that is for you speakers, the white, grey, purple, green harness. All you need is the rca one and then a harness to give your headunit power. It should be on with yellow, red, black and a remote wire (blue).
