Correct Wiring harness?
Old Mar 20, 2007 | 09:26 AM
Insanestang's Avatar
Insanestang
Default Correct Wiring harness?
Just wondering is this is the right harness for putting an aftermarket HU in.......
http://www.installer-data.com/item/d...php?it=70-5520
Old Mar 20, 2007 | 03:43 PM
ttocs's Avatar
ttocs
Default RE: Correct Wiring harness?
depends on what system is in the car. regular or mach?
Old Mar 20, 2007 | 04:00 PM
Insanestang
I have the mach.
Old Mar 20, 2007 | 04:25 PM
jst854's Avatar
jst854
i do not know about your ca due to the year, but on my 96 with the mach you need two harness the one you have to power your new radio and then another one for the speakers. They have a good one on crutchfield
Old Mar 20, 2007 | 04:30 PM
Insanestang
Is this the one your talking about?......
http://www.crutchfield.com/S-T1t0x4f...mp;I=120705521
Old Mar 20, 2007 | 08:00 PM
ttocs's Avatar
ttocs
that is part of it. That is the part that you need to wire into the decks hrns, all this will go in the dash. There is another hrns that allows you go bypass the amp. If you take that cover off and look at the amps hrns's that are plugged into it you will get a better idea of what it should look like. That hrns will do nothing more then connect the amps inputs, to its outputs, thereby bypassing the amp.
Old Mar 21, 2007 | 01:43 AM
seight311's Avatar
seight311
Information thread! Utilize it guys, if you think it's hard to read, don't worry im revising it all for everyone. The one thats got the harness for the 460 systems, (If you new head unit has front and rear outputs) is about halfway down, It's my post.
Old Mar 21, 2007 | 01:21 PM
ttocs's Avatar
ttocs
who is hard to read? halfway down where?
ORIGINAL: seight311
Old Mar 21, 2007 | 06:15 PM
seight311's Avatar
seight311
ORIGINAL: seight311
Old Mar 23, 2007 | 09:20 AM
Insanestang
Ok........I really just want to add my aftermarket headunit and a 500/1 amp to power a sub and to keep my stock mach amps and speakers for now. what harnesses will i need for that. All three or just 2?
