Mach system
Old Apr 8, 2007 | 10:44 PM
Nvarma's Avatar
Nvarma
Default Mach system
I have a question is it possible to get a Mach deck and hook a 400 watt amp to it and put a 12 in the trunk would that work? because I am really pressed for cash
Old Apr 8, 2007 | 10:46 PM
paperinacup's Avatar
paperinacup
Default RE: Mach system
If you got a mach deck then you'd have to have the amps for it, then youd need the speakers, when you go mach you need the whole setup. By a $150 pioneer deck with sub preout and use that if you want to add an amp. OR tap into the current system. Why is it you want the Mach HU?
Old Apr 8, 2007 | 11:43 PM
Nvarma's Avatar
Nvarma
I was just wondering. It seemed cheaper to buy someone elses old Mach than buy a new deck but, if you say it is just as easy as buying a new deck that I will do just that.
Old Apr 9, 2007 | 12:23 AM
paperinacup
Yeah man save your time and money and just get a new deck. Make sure you use the HPF (high pass filter) setting set it at like 100 or 125. The Pioneer 3900MP would be a great choice around $130-140. It has 3 preouts to use and an HPF and LPF. Probably the best you can get for that price.
Old Apr 9, 2007 | 01:48 AM
Nvarma's Avatar
Nvarma
Wow all that sounds great. Whenever I have the money saved I will look into that thanks.
bradleyb
Nov 27, 2015 07:50 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sixer4Life
Sep 29, 2015 07:03 PM
