Sony Subs??
Old Apr 10, 2007 | 05:23 PM
lighswitch's Avatar
lighswitch
Default RE: Sony Subs??
ummm i would wanna stay under like 300 or is that too low?
Old Apr 10, 2007 | 06:04 PM
seight311's Avatar
seight311
For an amp and a subwoofer(s)? Yeah.
Old Apr 10, 2007 | 06:23 PM
lighswitch's Avatar
lighswitch
Hmmmm well how much would i need for a small system 1 10 or 1 12 ?
Old Apr 10, 2007 | 06:42 PM
96Firebird's Avatar
96Firebird
Why does it matter what it sounds like outside of the car? Do you often sit outside your car and listen to your music?
$300 is enough for a budget system... $100 for the sub, $100 for the amp, $40 for wiring and $60 for a box (assuming you are getting a fre-fabbed box). But with a little more money, you can do so much better.
Old Apr 10, 2007 | 06:48 PM
lighswitch's Avatar
lighswitch
well yeah the system is jus for inside listening. so wat are some options u would suggest
Old Apr 10, 2007 | 11:06 PM
PReal's Avatar
PReal
I'll even start around $200....
Every setup assumes a $20 walmart install kit and a $40 for box construction materials. The only way to optimize your install is to build your own box. A prefab can be purchased for around $40, and building it yourself is much cheaper.
1. http://woofersetc.com/index.cfm?fuse...roduct_ID=3170500 watts rms, $100
and http://ikesound.com/product-product_id/2840350 watts rms output, $70
Total with wiring: $230
2. http://www.edesignaudio.com/edv2/pro...products_id=31400watts rms, $125
and http://ikesound.com/product-product_id/2212400 watts rms output, $100
Total with wiring $285
3. http://www.woofersetc.com/index.cfm?...roduct_ID=3068, 400 watts rms, $135
and http://ikesound.com/product-product_id/4352$115
Total with wiring: $310
There are a number of other setups I could put together, but this gives you the idea.
Old Apr 10, 2007 | 11:30 PM
96Firebird's Avatar
96Firebird
I like #2. eD is some good stuff. And since you said you didn't want it to weigh much, its a light-weight sub. My buddy has a Profile amp powering 2 subs, its a nice cheap amp that will put out around what its rated.
Old Apr 11, 2007 | 03:53 AM
lighswitch's Avatar
lighswitch
Wow that number 2 u said sounds like a flipping great set-up. just wat im looking for. and one more question would i have to get a new deck or could i be able to run it off the stock 6 disc?
Old Apr 11, 2007 | 04:58 AM
seight311's Avatar
seight311
Dear god, please get a new head unit. If you don't, give it 6 months until your 6 disc craps out, then buy a new head unit.
P.S. My vote is for #2.
Old Apr 11, 2007 | 12:54 PM
lighswitch's Avatar
lighswitch
Lol oh really that bad. i jus was gonna keep it cause this guy at this car audio shop said just keep it cause it will be jus as good as a new head unit so. sorry dont knw much about audio stuff.but thanx for all da help errrbody lol
