Alpine PLV-7?
Old Apr 11, 2007 | 11:42 PM
xcolt45's Avatar
xcolt45
Default RE: Alpine PLV-7?
PReal. Like I said earlier I'm new to this whole car audio stuff.
So. If I were to get the 130v2's would I need to get 2 of them. Would one sound good enough? would two over do it?
Basically what would you prefer exactly. I want it to fit into my trunk along with a bat bag. I'm guessin that means I'll need a grill of some sort also.
I listen to Rap and Heavy Rock none of that screamo tho. I would prefer the sub hitting every note rather than blowing my brain away and from what you told me earlier... both of these subs will do that.
I watched the videos but I don't know what to look for....
as there any more help/advice you could give me on this. I appreciate it a lot. Because (like I said earlier) these are brands that I've never heard of. but I trust ya. you know your S***
Old Apr 12, 2007 | 12:04 AM
PReal's Avatar
PReal
With the setups I already mentioned it states the number of subs that would work wellwith that amp.
In general adding another woofer addslike 3 db. Also, porting a box ofa single woofershould do close to the same thing. I only have one 12 in my pathfinder. If you remove your rear speakers to allow for bass passage, i think you should easily get away with a single12 with what your trying to accomplish.
You are already replaceing the HU so adding amps will be easy. Really I would do something like this for 5-6 hundred bucks....
Comps http://www.woofersetc.com/index.cfm?...roduct_ID=5207$100
Comp amp http://ikesound.com/product-product_id/4349$115
Sub http://www.edesignaudio.com/edv2/pro...products_id=31Dual 4 ohm, $125
Sub amp http://ikesound.com/product-product_id/4352$115
Wiring and Box built by you $70
Thats $525 for an entire setup that will be lightyears ahead of just adding subs for really really loud bass. If you really want good sound like you said, you have got to go full range hifi!
breaking
Oct 2, 2015 01:27 PM
Jun 14, 2005 08:34 PM
RCullan
May 6, 2005 10:16 AM
Krusher
Jun 21, 2004 05:45 AM
Krusher
Dec 20, 2003 12:12 AM
