Fox Body Double-DIN Setup
Old Apr 14, 2007 | 10:26 PM
ryanworrell520's Avatar
ryanworrell520
Default Fox Body Double-DIN Setup
Has anyone installed a Double DIN head unit in a fox body. I am looking to install a Pioneer AVIC-D3. IF you got pics of your setup or where you got the plates made I would love to see them.
Old Apr 15, 2007 | 02:47 AM
ttocs's Avatar
ttocs
Default RE: Fox Body Double-DIN Setup
I don't have pics but it should not be too hard. The after market kits just screw into the dash. If you get the kit with the EQ slot it should not be too hard to modify it.
Old Apr 16, 2007 | 12:13 AM
laserred38's Avatar
laserred38
Scoshe
yup shouldn't be too hard to modify this ^ to make it fit.
Old Apr 16, 2007 | 06:24 AM
ryanworrell520
ORIGINAL: laserred38
Scoshe
No I want to put a double DIN radio in, but it would have to be up to I think, and the ac ***** moved down
Old Apr 29, 2007 | 09:21 PM
baxt3r's Avatar
baxt3r
I had an AVIC-D1 in my '87 vert for a while.
The cage will fit in the opening and the reciever will just drop in and screw to the cage, iirc.
You will need to trim the trim ring for a proper fit since it is a little bigger than the opening.
I took the AVIC out because I wanted to go back to a stock appearance.
[IMG]local://upfiles/67975/E5140550FFB048B09816995532A74E9A.jpg[/IMG]
Old Apr 30, 2007 | 01:57 AM
ryanworrell520
ORIGINAL: baxt3r
Awesome thanks so much for the pic man, that's actually the exact stereo I was considering. I wanted to mount it at the top and HVAC controls at the bottom but I am thinking that it may be alot more work than it is worth, but then again mine is a stick.
Old Apr 30, 2007 | 10:48 AM
baxt3r's Avatar
baxt3r
I looked at mounting it up where the A/C conrtols are and decided I didn't want to do that much work.
A few concerns I had initially were 1) visibility, 2) hitting the shifter, and 3) getting to the controls.
Visibility was fine. Looking down to the stock radio opening was a little odd at first. Taking your eyes off the road and focusing, then looking back to the road took a little geting used to, but it was okay after an hour of seat time or so.
Having the AOD, the face will hit the shifter if you want to change CDs or put in another navigation DVD. You have to have the car in gear, or at least out of park. It was a minor nuisance, but I got over it. Having the navigation was worth it when trying to get to a show or somewhere I was unfamiliar with.
Getting to the controls was easier than I thought...especially with the car in gear. Since the controls are on the sides of the headunit, there wasn't anything that was difficult to get to at all.
One thing I have learned about the AVIc is that the GPS antenna will get pretty good reception through the dash plastic. I now have the AVIC in my '05 F-150 and the GPS antenna is inside the dash. The reception is perfect. I have teh GPS and XM antennas in the dash and I rarely lose signal from either. I figured I would pass this along since it might make the install go quicker and you might not want to see the antennas sticking out on the deck lid or roof or anywhere else for that matter. Just get teh antennas as high up in the dash as you can and I think you'll be pleasantly surprised.
Old Apr 30, 2007 | 02:56 PM
ryanworrell520
ORIGINAL: baxt3r
I was between that head unit and this Valor Navi System. They are almost exactly the same except the Valor uses 2GB sd card for maps instead of DVDs and it comes with all GPS, TV, XM attennas and the Bluetooth and Ipod cable built in. (The pioneer has like 10 different things to buy to use all of the features. With this, I would like never need to use the disc drive anyhow. All music and videos would be on ipod and the 2gb SD card would hold all the maps so no Nav DVDs.
http://www.valordvd.com/product/prod...ctid=NVG-670WT
Old Apr 30, 2007 | 04:22 PM
ttocs's Avatar
ttocs
that valor unit is a cheapie.............
Old May 1, 2007 | 12:45 AM
ryanworrell520
ORIGINAL: ttocs
Really? What makes you say that? Have you used it before?
