adding amp/sub to mach 1000
Old Dec 8, 2004 | 05:49 PM
pdk's Avatar
pdk
Default adding amp/sub to mach 1000
to the Mach1000 system:
is this possible to add an extra sub and amp to the M1000? any pointers
had bad experience with a stock head unit and wiring in the past and wanted to check before i get in there.
Thanks
Old Dec 10, 2004 | 02:06 AM
Redline03GT's Avatar
Redline03GT
Default RE: adding amp/sub to mach 1000
Yeah i think its possible, but it would probably be cheaper to just buy yourself a completely different system. Not a hundred percent sure though...
Old Dec 19, 2004 | 12:07 AM
narc29's Avatar
narc29
Yes you can, Im putting together all the parts now to add a JL 1000 mono and a JL 12W7 sub. Monster cable 4 gauge wiring kit, soundstream 5 farad cap and a LINE CONVERTER which is what you will need in order to run an amp. Im going to tap off the factory shaker rear speakers to run the line converter. Now if I coul just find someone to make me a custom box for the trunk! O ya, and DYNOMAT all around.
Old Dec 20, 2004 | 08:05 PM
pdk's Avatar
pdk
pulling the whole system would be ideal...but life ain't no fairy tale
was thinking about remounting the amps to make room for the sub or relocate the 2-10s and 1-12 into one box. (wanna keep the spare and still have a little room)
any input would be appreciated
narc-are you gonna have any trunk left?
Thanks for the replies
Old Dec 29, 2004 | 06:13 PM
narc29's Avatar
narc29
Just got the sealed 12w7 box and i still have about 2/3 of the trunk left, just waiting on the monster cable wiring for the amp and will be having it install by the jl dealer, will post pictures after its installed.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Oct 5, 2015 07:40 AM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
