Wiring Cigarette Lighter
Old Apr 30, 2007 | 03:33 PM
RanDJ8487's Avatar
RanDJ8487
Default Wiring Cigarette Lighter
Hey I was just wondering if someone could put me through the process of wiring my cigarette lighter by my shifter, so that it is on when the car is on and off when off. Thanks for all your help.
Old Apr 30, 2007 | 04:21 PM
ttocs's Avatar
ttocs
Default RE: Wiring Cigarette Lighter
there are two wires that go to your lighter. The ground is on the outside(looking from the back) and the hot wire is inthe middle. You will need to wire the middle wire to a +12v switched wire. You can find one behind the radio or at the fuse box. What are you going to plug into it?
Old Apr 30, 2007 | 04:25 PM
AJ06GT's Avatar
AJ06GT
ORIGINAL: ttocs
My first guess would be a radar detector, and if that's the case you can get a hardwire kit and wire it directly so you don't have to even plug it into the cigarette lighter. Really no matter what it is, I'd suggest wiring it directly unless it's something you want to be able to take out of the car frequently.
Old Apr 30, 2007 | 04:32 PM
RanDJ8487's Avatar
RanDJ8487
Well I was going to wire 4 way one for a light that goes behind the dash, eventually radar, and cell charger.
Old Apr 30, 2007 | 04:36 PM
AJ06GT's Avatar
AJ06GT
ORIGINAL: RanDJ8487
Ahh, well I think that I'd wire the light and radar directly into the car's wiring, then leave the cigarette lighter for the cell charger. That's just me though.
Old Apr 30, 2007 | 04:42 PM
RanDJ8487's Avatar
RanDJ8487
ORIGINAL: AJ97GT
ORIGINAL: RanDJ8487
And I can just wire them the same place? Sorry I'm kinda new to it and I know it's very basic.
Old Apr 30, 2007 | 04:51 PM
AJ06GT's Avatar
AJ06GT
ORIGINAL: RanDJ8487
ORIGINAL: AJ97GT
ORIGINAL: RanDJ8487
It depends, but probably yes. Anything that plugs into a cigarette lighter is going to use 12v just like almost everything else in your car. No matter how much you have running off of one wire, it's always going to be 12v. The thing you have to worry about is amperage. To do the job properly, you will want to get a meter and see how many amps you're getting on the wire you want to use for your 12v, then check the different components you want to power with it and see how many amps they want to run and make sure you have enough. I would guess that you can probably run a small light and radar off a majority of 12v lines in your car, but don't quote me on that. I don't know how much power is running through them all.
Old May 30, 2007 | 07:50 PM
blackstalion232's Avatar
blackstalion232
neither of my ciggeratte lightersin my 98 vert work and then i looked in my chilton and the diagram in there was diffrent form what is under my hood or the dash so i was wondring if someone could tell me what fuse # they would be and mabey what other things could be wrong or why there not working
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
