Help with building box. Need measurements.
I have two 12" subs I am building a box for. I am going to get a 3/4 inch thick plywood and cut it and everything. Now both subs are going in the box and I was wondering how far apart the subs should be from each other and how far the subs should be from the top, bottom, and sides of the box. Thanks.
Make sure you buy MDF not plywood.
The only issue with the space inbetween them relates to the strengh of the enclosure. MDF is much much stronger then standard plywood and even a couple inches between the two will allow for enough area to absorb the weight of the subs.
daltron
Apr 28, 2016 08:10 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
