Is this to much
Old May 8, 2007 | 07:31 PM
vt89gtvert's Avatar
vt89gtvert
Default Is this to much
I am running 3 but soon to be adding a 4thamp in the trunk of my car and had some questions I thought yall might be able to help with.
The system is as follows:
R series alpine speakers all around in the car, with two amps pushing them one is 4x100 and the other is 2x100.
Two infinity Perfect 10" subs in a custom box in the trunk with one amp pushing the at 250x2. I am thinking about adding another sub I have sitting around so I will be running the with 2 amps, 500x1 and 575x1.
I am just running three amps right now, but if I add the last 575x1 sub will it cause to much heat in the trunk, and will my 4 guage wire going from the battery to the trunk handle that much load. I just installed a 100amp fuse on the incoming line to my distribution box in the trunk. Any thoughts would be great.
Old May 9, 2007 | 12:28 PM
PReal's Avatar
PReal
Default RE: Is this to much
First, It would help to have the model and brand of your amps.
Second, all those amps is a very poor idea. For the subs you should buy a single class D amp that is efficient enough to power the subs. Why on earth do you have 6 channels of amplified speakers in the cabin, do you have 5.1 surround?
Third, I pray that the third sub you are thinking of adding is another Perfect 10", if not do not add another woofer.
Old May 9, 2007 | 09:59 PM
vt89gtvert's Avatar
vt89gtvert
Sorry, I was having a retarded moment. I have oneamp(250x2) pushing the two subs right now, and am looking to have two amps pushing the two subs (I am not going to add anouther sub). Iwant the 6 channels of amplified speakers because I already have them in the car. I am running the front 4 amplified by the amp and the back two by just the deck (Like 17 RMS watts). So since I got a good deal on a 100x2 amp I thought I might as well get them all sounding good. That and I drive a convertible, so at 70 MPH it takes some watts to get the soudns clear (And me deaf).
Old May 10, 2007 | 10:33 AM
PReal's Avatar
PReal
I wouldn't waste any money on adding an amp for your rear speakers. Instead, look into getting some sound deadening to help reduce road noise.
I would recommend buying a single larger class D amp (around 1000 watts at 1 ohm) instead of running multiple class A/B amps. They are more effecientt and will put less strain on your electrical system.
