radio
Old May 9, 2007 | 11:06 AM
stangant's Avatar
stangant
Default radio
ok im putting in a new head unit and i need to know how to wire this mess. ive never seen that many wires go to a stock headunit before. is there a diagram i can find?
Old May 9, 2007 | 11:21 AM
Insanestang's Avatar
Insanestang
Default RE: radio
what system do you have? If you have the 460 you should have two harnesses coming from the car into the stock headunit.... is that what you have? Cause then its simple... you will just need two wiring harrnesses.
Old May 9, 2007 | 11:42 AM
stangant's Avatar
stangant
Default RE: radio
no i have the stock 2000v6 duel stag head unit
Old May 9, 2007 | 11:44 AM
Insanestang
Default RE: radio
have you taken it out and seen the pulgs going into it?
Old May 9, 2007 | 11:51 AM
stangant's Avatar
stangant
Default RE: radio
yea there is 1 main plug then 2 big plugs, ground type wire and then the aenena wire thats just in the main 1 then there is the cd drive
Old May 9, 2007 | 01:27 PM
mustangman02232's Avatar
mustangman02232
Default RE: radio
go to wal mart or something of that kind and they have adapters that you plug the harnesses into and wire your new head unit to, what componts you going with?
Old May 9, 2007 | 01:30 PM
cisurfer's Avatar
cisurfer
Default RE: radio
ok i have the same one you have and it took me awhile to figure it out.....theres a external amp you can see sitting in the bottom of the dash under the radio...its silver...i took this out. In the wiring harness you buy one will clip into a harness for speakers....the one that come out of the amp is for the speakers.....the other one thats a wierd shape with the orange red yelloow and black wires is you power and anopther hrness will connect to that....that one small ground that plugs into the back of the radio is just for the amp dont worry about that
Old May 9, 2007 | 10:04 PM
gyea's Avatar
gyea
Default RE: radio
Yeah go with adaptors saves you big time if you even want to return to stock 1 of the best investments in audio just get a good one!! there are ****ty adaptors that dont make good connections......
Old May 10, 2007 | 11:04 AM
stangant's Avatar
stangant
Default RE: radio
are u sayin that i use the stock amp with a a/m headunit? and where can i get the adapters and also the fillerfaceplates for the cd player hole?
Old May 10, 2007 | 12:46 PM
mustangman02232
Default RE: radio
there is a tray to replace the CD player, id just gut everything and go with a bunch of aftermarket componets
