radio
Old May 10, 2007 | 02:53 PM
cisurfer's Avatar
cisurfer
Default RE: radio
i took out the stock radio, the stock cd player, the stock amp....disconnect all harness from everything you take out.........go buy a wiring harness for your car.....one of the harnesses will be a grey l shaped one which sonnects to the power harness.....another will be for the speakers which will be a rectangle or square and connect to a plug that you unplugged from the amp....you are not using the amp with aftermarket radios......you can also buy a pocket from crutchfield to fill in the cd player hole
Old May 10, 2007 | 02:56 PM
jovez's Avatar
jovez
Default RE: radio
I just said forget it and a rewired the whole thing myself. Much easier that way i thought.
Old May 11, 2007 | 03:41 AM
ttocs's Avatar
ttocs
Default RE: radio
Mustangs are some of the easiest cars to put radios in. With the proper tools and parts I can be in and out in 10 mins.......................
It is always easier with the hrns.
Check page 2 of my sig and see if the hrns's look the same.
ORIGINAL: jovez
Old May 11, 2007 | 10:41 AM
stangant's Avatar
stangant
Default RE: radio
why can i not use the stock amp?
and i might just replace it with a new 1.
how many whats is the stock amp?
Old May 11, 2007 | 10:47 AM
stangant's Avatar
stangant
Default RE: radio
cruchfield has an adaptor that plugs into the amp and a/m radio.
http://www.crutchfield.com/S-twimTTP...mp;I=142C4FDK5
Old May 11, 2007 | 12:51 PM
ttocs's Avatar
ttocs
Default RE: radio
its junk........ You can use it how ever if you ever add a sub then you will know why. That amp will distort and sound like crap long before even the new HU CD player would. Take my work for it you don't want to use it.
ORIGINAL: stangant
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
vbonina
Sep 22, 2015 08:31 AM
Gkid182
Sep 22, 2015 08:17 AM
unit91
Sep 15, 2015 09:53 AM
