Big 3 Upgrade
Old May 17, 2007 | 11:08 AM
pikuoff's Avatar
pikuoff
Default Big 3 Upgrade
I just ordered the kit from eD. Anyone know ofor have any good writeups on how to go about doing this. I don't want to pull the wrong wire and would feel better knowing exactly which wires are what when I dive in there.
Thanks!
Old May 17, 2007 | 11:41 AM
PReal's Avatar
PReal
Default RE: Big 3 Upgrade
All you are doing is basically replacing the primary wires that connect the battery. You can even just add additional wires if you like.
Old May 17, 2007 | 11:51 AM
pikuoff's Avatar
pikuoff
Do I need new battery terminals then?
Old May 17, 2007 | 12:04 PM
bobbyboura's Avatar
bobbyboura
no just get a crimp conector with the hole to fit the temanal take it off put it through the bolt then bolt the termanil to the batt ot you could cut the wire and splice into it with the new one
Old May 17, 2007 | 12:07 PM
PReal's Avatar
PReal
ORIGINAL: bobbyboura
I would recommend doing just that with high quality ring terminals. (They probilbly came with your kit)
I would also go ahead and replace the terminals with a good quality brass or gold plated piece.
Old May 17, 2007 | 12:21 PM
pikuoff's Avatar
pikuoff
Seems pretty simple then. Thanks!
Old May 18, 2007 | 03:35 AM
seight311's Avatar
seight311
Im 95% sure your kit came with the connectors, I cant imagine it cost $50 for three 4 ft. pieces of wire...
Are you being a manand going with1/0 ga?
Or are you a huge ***** and using 4 ga?
Old May 18, 2007 | 10:29 AM
pikuoff's Avatar
pikuoff
Yea I noticed it's got all of the connectors in the kit. Just wasn't sure about what gets hooked up where and if I needed to cut any OEM wiring.
I guess I'm being a huge ***** and using 4 ga but I asked eD which kit to get and that's the one they said to get for my set up. So I guess they a making me a *****...[&o]
Old May 18, 2007 | 11:16 AM
PReal's Avatar
PReal
I'm using 1/0 for around 1200 watts rms. Overkill puts hair on your chest!
Old May 18, 2007 | 12:36 PM
pikuoff's Avatar
pikuoff
I think I already got plenty of hair on my chest...damn my father for telling me to be a man and drink Wild Turkey when I was 13 b/c it would put hair on my chest...[:'(]
