Mach 460 front speaker replacement?
Old Jun 20, 2007 | 06:48 PM
jmmorgan82's Avatar
jmmorgan82
Default Mach 460 front speaker replacement?
What is the best option to replace the speakers? a 5x7 component or 6.5'? Mine are shot and I am going to bypass all the factory stuff so i just need a little input. Thanks.
Old Jun 20, 2007 | 07:36 PM
ttocs's Avatar
ttocs
Default RE: Mach 460 front speaker replacement?
you will get better sound from a componant speaker if you have good enough power for them. Otherwise you will not tell much difference between the two sizes. If you have replaced the stock radio it will be no problem to wire them up, I can get you through it.
Old Jun 21, 2007 | 12:02 PM
jmmorgan82's Avatar
jmmorgan82
I'll have no problem wiring them up, I've already wired up the rear ones. I just need to know what size the front ones are for replacement.
Old Jun 21, 2007 | 04:15 PM
ttocs's Avatar
ttocs
They are the same front and rear, 5 x 7 and 2.5.
dubarado
Dec 23, 2015 01:16 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
kdryan
Aug 26, 2015 05:54 AM
Aug 21, 2015 12:54 PM
69FB
Aug 18, 2015 08:50 PM
