Speaker noise.
Old Jul 11, 2007 | 12:37 PM
PReal's Avatar
PReal
Default RE: Speaker noise.
ORIGINAL: SchweinoPower
Ok. There are 2 grounds it looks like comming from my negative on the battery to the chassis. But they are bolted down on top of the paint. Should I try an remove the paint around those 2 grounds?
Will making a fresh ground comming off the negative remove the problem?
You should probilbly just go ahead and upgrade the big three. The info sticky has a great explanation.
Old Jul 11, 2007 | 01:12 PM
ttocs's Avatar
ttocs
check out my sig on page 3 err 4 and it shows the big 3 upgrade I did. It would be better to remove those grounds, clean the area under it and then re-attach them but I don't think that is where your noise is commin from. I think BBY didn't re-run the speaker wires the way you asked them to....
Old Jul 11, 2007 | 04:25 PM
SchweinoPower's Avatar
SchweinoPower
Thanks for the idea about the big 3, might as well upgrade it
I'd really like to learn how to do this myself. So for my 400w RF amp, do i get 4 AWG wiring for all 3 wires? Im not sure how the gauging system works...
Just funny, ive probably spent all this money an its still not right. Guess everyone learns the hard way
Old Jul 12, 2007 | 04:08 PM
ttocs's Avatar
ttocs
you want thick wire for your power wires and you want them all the same size.
Most of us do learn the hard way, I did........
Old Jul 12, 2007 | 09:13 PM
SchweinoPower
And the grounds I can use regular speaker wire (16 awg)?
Old Jul 12, 2007 | 11:42 PM
SchweinoPower
Completly aside from the original topic, but I want to make sure I understand this correctly. My HPF for my front stage is set to 50 hz. This means that they will play anything above that, and cut out anything below that?
Old Jul 13, 2007 | 09:15 AM
ttocs's Avatar
ttocs
power wires are both the ground and the power. They both need to be the same thickness and as thick as possible.
You have the hpf correct, it plays anything abot 50 hz.
Old Jul 13, 2007 | 03:55 PM
SchweinoPower
www.schweinsburg.com/brad/home.htm
I posted some wiring pics. Lemme know if yall need anything else. The main question I had was deck ground going to my amp, and I took a pic of the ground for my amp.
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
Doogie65
Sep 6, 2015 02:55 PM
TimeLord101
Sep 4, 2015 09:27 AM
