wiring problem
Old Jul 15, 2007 | 02:50 PM
justinmac86's Avatar
justinmac86
Default wiring problem
Hey guys I recently just got a new truck so I wasn't driving the stang all the time and I had to get a little bass in there too. I've installed several stereos but I'm having trouble with this one and was wondering if anyone had any ideas. I've got the sub and amp all wired in and when I turn the key on the light on the amp comes on for a few seconds and then fads out and I cant figure out what the problem is. I have a good solid ground (I sanded the paint off the floorboard), there are no fuses blown, and my power on cable is spliced into the cigarette lighter since I'm keeping the stock deck. I'm sure its a short somewhere but I'm completely lost, does anyone have any ideas?
Old Jul 15, 2007 | 03:43 PM
seight311's Avatar
seight311
Default RE: wiring problem
Your factory wiring harness still has a ignition wire. I would tap into that, not your cigarette lighter. If nothing else, put it on a switch.
Old Jul 15, 2007 | 04:04 PM
justinmac86
Do you think this is why it only stays on for a short while? I thought that all it needed was a constant 12 volt source of power, isn't that what a cigarette lighter is?
Old Jul 16, 2007 | 04:15 PM
y2kStangGT's Avatar
y2kStangGT
why didn't you run the 12v directly to the battery?
i don't think the wire you are using is big enough.
the amp requires alot of power, i don't think the cig. lighter fuse can handle it. check your fuse box.
Old Jul 16, 2007 | 04:16 PM
y2kStangGT's Avatar
y2kStangGT
i've never heard of anyone tabbing the 12v to a cig lighter.
that would not work for an amp.
Old Jul 16, 2007 | 04:18 PM
y2kStangGT's Avatar
y2kStangGT
ORIGINAL: justinmac86
wait.
your power on cable?
did you mean the remote cable?
Old Jul 16, 2007 | 06:34 PM
justinmac86
Ya my bad, I think I miss spoke, the remote cable is spliced into the cig lighter wire. This should work right?
Old Jul 16, 2007 | 10:49 PM
y2kStangGT's Avatar
y2kStangGT
it should work, but i wired mine to the antenna/remote wire, which is the blue wire if you have an aftermarket HU.
check your fuse from the fuse holder next to your battery. I had the same problem this weekend.Mine didn't look blown until i disconnect the holder and took out the fuse. It was cracked. replaced it with a new fuse and boom. everything works perfect.
Old Jul 17, 2007 | 02:15 AM
65PonyLove's Avatar
65PonyLove
I have a 65 stang and in mine the cig lighter has consant power. If yours does too, then you need to wire your remote to an accersory wire (only comes on with the turn of the key, and NOT constant power) Then make sure your ground is secure, power (red thick cable) is connected properly to the battery, then you should be good. An amp install is not complicated at all. Back, Red, gives it power, but you still need a turn on/off and a signal (RCA cables) With these 4 things you cant go wrong
[/align]
Old Jul 17, 2007 | 06:15 AM
silver2006's Avatar
silver2006
what i would do is unhook the speakers and see if it stays on then. if it does then check your speakers, if not jump arcoss the 12v power to the remote turn on. if it stays on then you know you need a different remote connection(maybe even wire). if it doesn't stay on then you need to check your 12v and ground connection. i would take a set of jumper cables and connect the amp right to the battery, if it stays on then you know it's the 12v power or ground connection. if it doesn't stay on now, it's time to buy a new amp.
2007StangV6
Jan 28, 2016 06:09 PM
Doogie65
Sep 6, 2015 02:55 PM
zanemoseley
Sep 6, 2015 12:58 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
