stereo keeps cutting in and out...dont know what it could be
Old Jul 20, 2007 | 06:48 PM
Eduardo's Avatar
Eduardo
Default stereo keeps cutting in and out...dont know what it could be
I'll be listening to my music and if I turn a corner a little too sharp or barely turn a little or go over a bump it goes out and comes back on when I turn or go over a bump again. The speakers and sub both go out. What is going on?
I have a JVC headunit with the compatible wiring harness for the mach 460
stock speaker and amps
10inch infinity sub
crunch 1000w amp
Old Jul 21, 2007 | 12:27 PM
Eduardo's Avatar
Eduardo
Default RE: stereo keeps cutting in and out...dont know what it could be
bump
Old Jul 21, 2007 | 05:15 PM
PReal's Avatar
PReal
It sounds like you have a loose connection.
I would check over every connection starting from the battery to the amp.
Old Jul 21, 2007 | 05:24 PM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
Definitely sounds like a wire is loose.
It usually happens to me at the amp.
But only my subs would go out.
Old Jul 23, 2007 | 10:30 AM
laserred38's Avatar
laserred38
LOL. Does it happen when you are listening to the radio? Or just the cd player. Because if it is only the cd player...it is probably just skipping. If it does it with the radio too, then you probably have a loose connection on the back of the HU since both the stock speakers AND subs cut out.
Old Jul 24, 2007 | 11:27 AM
Eduardo's Avatar
Eduardo
Could it be the remote wire?
Old Jul 24, 2007 | 11:47 AM
PReal's Avatar
PReal
Maybe.
Like I said verify all your connections are tight!
Old Jul 24, 2007 | 07:26 PM
laserred38's Avatar
laserred38
Could be, but the door speakers being ran off the HU wouldn't cut out if the remote wire was loose.....right?
jwog666
Dec 27, 2021 08:09 PM
jrrhd73must
Oct 2, 2015 09:17 PM
mdg
Oct 1, 2015 07:04 AM
vbonina
Sep 22, 2015 08:31 AM
TimeLord101
Sep 4, 2015 09:27 AM
