ground wire
Old Jul 22, 2007 | 02:20 PM
stangman2354's Avatar
stangman2354
Default ground wire
my cd player came with a ground wire with a metal connector on it to bolt down onto a screw. I can't find a screw behind where the cd player goes. So I was thinking of extending the ground wire and hooking the ground wire to one of the bolts that holds down the driver seat. Would this work? And can I extend the ground wire by splicing it with any type of wire, like speaker wire?
Old Jul 22, 2007 | 02:56 PM
ttocs's Avatar
ttocs
Default RE: ground wire
a ground wire should be as short as possible. I just grounded something to the bolt that holds the shifter down yesterday but if you cannot find a good spot then use the factory ground in the radio hrns..
You can splice a ground wire with what ever you want to extend it. wire is wire is wire.
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
