system in vert
Old Jan 26, 2005 | 10:17 PM
bob3339's Avatar
bob3339
Default system in vert
I have an '04 vert Gt if that means anything and was wondering what I could fit into my trunk system wise. The catch is I need to be able to fit my golf clubs in the trunk also. Is this possible?
Old Jan 27, 2005 | 12:29 AM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
Default RE: system in vert
amp mounted ON the back of the rear seat from trunk. than get 2 10" subs and squeeze them as close to the seat from the trunk as possible. should have enough room for clubs and a duffel bag. thats what my brother did.
or you could pay more and get the subs mounted facing the taillights from the back of the rearseat (1 sub per seat) and mount the amp on the side next to the seat in trunk. that would leave more room, but be careful putting seat down cuz the wires may be snug. also when doing it this way, you might need to stiffen the rear seat with plywood or fiberglass and seal it airtight for sound quality. also sitting in the rear seat might hurt your back.
Old Jan 27, 2005 | 01:36 PM
mattwilliams's Avatar
mattwilliams
I have problems putting my tool box in my trunk....i have 2 12's
Old Jan 29, 2005 | 11:53 PM
rd04svt's Avatar
rd04svt
I have an '04 vert and had a simular problem. I replaced the entire system and added a sub in the trunk. The custom fit sub unit from JL is nice but it will set you back about $400....too much for me. I went to the local pawn shop and found a 10" sub box (Q-Logic) for a truck and modified it to fit. I mounted the amps to the side of the box and still have enough room for a small travel bag. It sounds great...just enough bass with the top down.....
Old Jan 31, 2005 | 07:21 PM
rd04svt's Avatar
rd04svt
http://www.crutchfield.com
try this....
Old Feb 1, 2005 | 12:54 PM
YinYangStang's Avatar
YinYangStang
You can look into what md did with his system. Remove the spare tire and sink the subs into the well and seal it. If you put a stiff metal cage over the tops of the subs, all you have is a loss of a few inches, and you can put anything on it.
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
