Audio Wiring
Old Aug 8, 2007 | 11:29 PM
jerod187's Avatar
jerod187
Default Audio Wiring
hey guys i got a 1991 mustang lx and i got my sub and amp ready but i need install the new cd oplayer i had a jvc one in before so already got all stuff needed to put the new pioneer in but do you guys have a diagram of what each wire is? by color thanks, jeremy
Old Aug 9, 2007 | 12:00 AM
jerod187's Avatar
jerod187
Default RE: Audio Wiring
ok double screwed guys i went out and i realized my interior lights arent working so i musta done something when i was putin my deck in?? any idea blown fuse, something came disconnected??
Old Aug 9, 2007 | 12:05 AM
79bronco's Avatar
79bronco
Did you short anything out? check your fuses...if you have a blown fuse i woul dsuggest you go back and re check all your connections to insure a good connection and also a properly insulated conection...I would say just go check that all out your better safe than sorry...
Old Aug 9, 2007 | 12:15 AM
jerod187's Avatar
jerod187
ya im gonna check all that in the morning but i got o lites so i cant c right now lol! but all the fuses are under the dash right should i jus check out all those fuses out?
Old Aug 9, 2007 | 12:22 AM
79bronco's Avatar
79bronco
check all the fuses in the car...
Old Aug 9, 2007 | 12:24 AM
jerod187's Avatar
jerod187
kk will do gonna try that tomorrw morning
Old Aug 9, 2007 | 05:27 AM
FordMustangXBA's Avatar
FordMustangXBA
First check if the fuse is good...If it is, and you have a test meter or light, put one end on each end of the fuse and see if there's current...If not, then there's a wiring problem.
Old Aug 9, 2007 | 06:32 AM
stang8689's Avatar
stang8689
wire it up without factory wires, run all new speaker wires, run a new ground, run the yellow to battery or fuse panel with a constant power source, and red to a power source of choice depending if you want the stereo to turn off with the key
Old Aug 9, 2007 | 09:08 AM
importkiller89's Avatar
importkiller89
y didnt u just go to walmart n get the wireing harness n it tells u what wires to put were plus every day low prices
Old Aug 9, 2007 | 09:16 AM
98MustangGT46's Avatar
98MustangGT46
ORIGINAL: importkiller89
This is what you should of done.. Now your gonna have to do what stang8689 said un less you figure it out of course..
