Audio Wiring
Old Aug 9, 2007 | 09:22 AM
daleclough's Avatar
daleclough
Default RE: Audio Wiring
ORIGINAL: stang8689
wire it up without factory wires, run all new speaker wires, run a new ground, run the yellow to battery or fuse panel with a constant power source, and red to a power source of choice depending if you want the stereo to turn off with the key
just did this. tried it with factory wiring and it really sucked. ended up running new speaker wires, etc....
good luck!
Old Aug 9, 2007 | 10:25 AM
jerod187's Avatar
jerod187
hmm ya well a new wire harness wouldnt of dne anything because theres alreaedy 1 in there from before cuz theres a diff deck it in it already
Old Aug 9, 2007 | 11:22 AM
jerod187's Avatar
jerod187
hey guys thanks for the help ya i turned out just being a blown 15A fuse so it works now! buttt lol for some reason cant get any sound but should be able to figure it
Old Aug 9, 2007 | 02:13 PM
98MustangGT46's Avatar
98MustangGT46
Ok well good luck.. Let us know if you need more help man..
Old Aug 9, 2007 | 06:46 PM
nyfreakinrican7's Avatar
nyfreakinrican7
Is it possible you have a factory amp that you have not bypassed. That's what happened to me
I kept trying different radios I had in the garage and not getting any sound till I put one that I knew had to work and still no sound so I investigated further and I had a factory amp right behind the radio.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
