SN95 Wheres your ground
Old Aug 9, 2007 | 03:41 PM
RanDJ8487's Avatar
RanDJ8487
Default SN95 Wheres your ground
Well i have 2 amps in my car and the sub one, the more powerful of the 2 keeps blowing fuses. I am assuming a bad ground. I can't really find a decent one that the wire can reach. My amps are behind the back seats and the ground I am using right now is the frame to the back seats. Anyone find a better place? Not the saviest in drilling new holes.
Old Aug 10, 2007 | 09:32 AM
ttocs's Avatar
ttocs
Default RE: SN95 Wheres your ground
what equipment do you have, how do you have it wired? Grounds normally do not cause fuse problems as much as putting too much on the amp.....
Old Aug 10, 2007 | 09:35 AM
RanDJ8487's Avatar
RanDJ8487
i dunno i had an amp before and I thought it was bad wiring so I replaced it. Still blowing fuses, so I got another amp, now it's blowing fuses. Even with the amp turned down, it will blow
Old Aug 12, 2007 | 05:57 AM
kura's Avatar
kura
I used the same ground for a RF t10001 and didn't have any problems. Did you sand off the paint on the boltand frame?
Old Aug 12, 2007 | 04:35 PM
ttocs's Avatar
ttocs
again, what is wired up to the amp as far as speakers?
Old Aug 12, 2007 | 08:07 PM
RanDJ8487's Avatar
RanDJ8487
2 Kicker CVR12s. I just sorta relocated the grounds a little bit. Got new terminals for the wires that fit better, so far, no blow.
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
uedlose
Sep 10, 2015 03:30 PM
