adding 6.5 inch components in front. Wiring questions.
Old Aug 16, 2007 | 07:34 AM
stealthyone's Avatar
stealthyone
Default adding 6.5 inch components in front. Wiring questions.
Ok, I finally found the data cable in the back and got my LOC wired in for my sub in back, now I want to tackle the front stage... other than tapping the wires rigt at the speakers, what is a good way to add and amp to power my own front speakers? I know the front amp is under the radio, but what wires do I splice? I am looking to do away with my rear speakers completely and just have my front components running on my 100W 2ch amp, and my sub running on my 400W Mono amp. Can I just tap into the front outs straight off the deck?
Help?
Thanks.
Old Aug 16, 2007 | 12:19 PM
ttocs's Avatar
ttocs
Default RE: adding 6.5 inch components in front. Wiring questions.
yes and no....... There are a couple of hrns's in the dash and as long as we get you to the right one there will be no problem. it will not be the hrns that was plugged into the deck, it will look like the one I am pointing to on page 2 of my sig, depending on the year.....
Old Aug 16, 2007 | 01:27 PM
stealthyone
Great thanks for the help... lets see, page two in yor sig.... Um, I dont see your sig.
My car is an 02 gt with Mach460 in it if it helps. I basically need to know what harness, where it is, and what colors are front right pos and neg, and front left pos and neg.
I was hoping you would chime in. thanks. Now if I can only find your sig.
Mike S.
Gene K
Oct 21, 2015 11:37 PM
mungodrums
Sep 28, 2015 05:45 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
cbird1177711
Sep 2, 2015 08:51 PM
