Flip Switch to turn on Amp
Old Aug 21, 2007 | 11:39 AM
850SN95's Avatar
850SN95
Default Flip Switch to turn on Amp
Alright i need a little help, i have an amp that i want to wire up an toggle switch toso i can manually turn the amp on and off.
http://cgi.ebay.com/12-Green-Led-Lig...QQcmdZViewItem
i think i have an idea on how to wire it up but i just want to know if its gonna work before i screw anything up or get electricuted!
SO HERE's MY PLAN
i run the positive wire from the toggle switchto the battery, and then run my ground wire from the toggle switchto a good ground, and thenrun the remote turn on wire from the amp to the togle switch. Is that the right way to hook up the toggle switch to my amp?
ANY HELP IS APPRECIATED
Old Aug 21, 2007 | 12:51 PM
ttocs's Avatar
ttocs
Default RE: Flip Switch to turn on Amp
you can get those at almost any autoparts store but your wiring is 10 times harder then it needs to be.
there are 3 contacts on the switch but you only need to use 2 of them(the middle and one of the ends). Run the remote turn on wire from the deck, to the switch(either side), and then from the other pin on the switch to the amp remote turn on. You do not need to touch the constant or the ground. This will allow you to cut power on the remote turn on, which will turn your amp off.
jma2
Jul 10, 2023 01:00 AM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
9550
Oct 26, 2015 05:01 PM
Meystang
Sep 25, 2015 04:05 PM
cbird1177711
Sep 3, 2015 08:43 PM
