question on installation on system
Old Feb 5, 2005 | 10:26 PM
bizarre660's Avatar
bizarre660
Default question on installation on system
i have a system from another car that i want to put in my 04 gt. a few questions so im not screwin my car up. is there an easy way of getting the wire from the battery to the box through the firewall with out having to drill? also do most of the interior pieces just snap off? lastly does anyone know what wire i would need to hook up the rca wires to the head unit since i still have the stock one? thanks
Old Feb 6, 2005 | 12:54 AM
iluv2gofast's Avatar
iluv2gofast
Default RE: question on installation on system
Not sure if this will help but click on the post I started a couple of days ago in this forum title "where to install line converter".
Old Feb 6, 2005 | 05:41 AM
Acewelder99's Avatar
Acewelder99
i had to drill a hole in the fire wall for the power wire make sure you run your rca's on the other side of the car as you power wire, it will help keep down on the noise
Old Feb 8, 2005 | 01:49 AM
mattwilliams's Avatar
mattwilliams
I drilled a hole in my fire wall, but make sure that you buy a rubber grommet to but between the metal and the wire, cause eventually the metal will rub through the plastic cover on the wire. To install the RCA cables and a remote wire here is what you do. For the RCA's buy a line out converter, and follow the directions. You just tap into your rear speaker wires. Then plug the RCA's into the line out converter. And on the remote wire, just run it to a wire that only becomes hot when the car is turned on.
Old Feb 8, 2005 | 10:50 PM
goatman's Avatar
goatman
I replaced all the speakers in my 04, and the deck. Let me know when you need help in those areas - todd_keagle@yahoo.com.
Thanks to this forum, I was able to do it on my own without breaking much, and saved about $100.
Old Feb 10, 2005 | 10:36 PM
bizarre660's Avatar
bizarre660
thanks for the help. i got the line out converter now i just need a box that can fix in this little trunk of mine.
Old Feb 16, 2005 | 03:25 AM
mattwilliams
I have 2 12's in a sealed q-logic box that i got at circuit city....it fits
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
DrunknRuckus
Aug 23, 2015 10:05 AM
dseg
AmericanMuscle.com
Aug 10, 2015 03:29 PM
