projector light wiring help plz
Old Aug 30, 2007 | 09:49 PM
Five O Ghost's Avatar
Five O Ghost
Default projector light wiring help plz
i ordered some 95 mustang GTone piece SONAR headlights and the the headlamps came wired. but between those and where the side marker light goes, there are 3 vertical lights that are wired together (all 3 whites are grouped and all 3 blackes are grouped). also there are 2 sets of black and red wires coming from the bottom but i don't see what they go to. my question is what do these wires do and where or what do i wire them to.
Old Sep 2, 2007 | 12:59 PM
ttocs's Avatar
ttocs
Default RE: projector light wiring help plz
you can wire them to what ever ya want. If you want them to come on with the marker lights then connect the white to the brown, and ground the black.
Old Sep 2, 2007 | 08:22 PM
Five O Ghost
go it. thanks.
Old Jan 31, 2008 | 06:48 PM
royjohnston's Avatar
royjohnston
What about the "2 sets of black and red wires coming from the bottom "? I have the same lights and have tried it all.All other posts on other forums said Black to black and white to Green. But my turn signal wires are black, brown and green/white stripe.
Old Feb 1, 2008 | 10:08 AM
ttocs's Avatar
ttocs
ground the black and then you probably want those to turn on with the parking lights so connect the red to your factory brown wire.
Is thata pic of a mustang in your avitar?
Old Feb 1, 2008 | 10:25 AM
royjohnston
Yes. That is my mustang. Actually it was my 16 year olds until he wanted a Durango. then I passed it onto my 14+ year old. We are using it as a bonding experience. He has joined a car club and also want to show it. We are upgrading the interior with factory molded carpet (black) and covering existing seats from local upholstery shop. Also cFiber interior. Paint job royal blue n gun metal grey....on and on and on. $$$$.
But to answer all questions about the sonar halo 2 headlights. I have a 95 GT 5.0 mustang. Here is how to wire them into running lights:
1) The 2 red wires and the white wires that are grouped into 1 connect to the turn signal BROWN wire.
2). The 2 black wires and the black wires that are grouped into 1 ground the to chasis. I used a countersink screw and u shaped connector to connecct.
When I turn on the lights, the halos and the other little lights come on. No problem.
Hope this helps.
Old Feb 1, 2008 | 12:54 PM
ttocs's Avatar
ttocs
to each his own I guess.....
the brown wire on the hrns is the wire that controls the parking lights. With out knowing the color code to the ricelights you have I will guess that the white wire on them is to the parking lights and the possibly the halo's? If that is the case then they need to go to the brown factory wire, if you want the white led's to light up at the same time then connect the red wires on them to the brown wire also.
Are these HID or projector? This is gonna sound like a stupid question but the new lights have bulbs in them already right? You have looked?
Ford_Dude
Sep 15, 2015 03:25 PM
jaiidutch
Sep 14, 2015 10:29 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
