Filling in the hole
Just wondering if i get an aftermarket head unit what whould i use to fill in the excess space below the radio. I have the 6 disc cd changer and if i get a regular radio/cd player i know that its going to be much smaller. also what wiring harness.Any ideas????
you can get face plate when you buy the radio. it fills in the space with a little storage comparement for sunglass, or cell phones. as for the wire harnessmost places that sell radios will have what you need. you will also need a 5volt regulator so when you turn on the radio you don't get a pop from your speakers. the factory amps only need a 5volt remote the new radio will be 12volts.
when you buy the dash install kit it has a little plastic compartment for the bottom part as said.
just go to bestbuy or any audio shop and tell them you need a wiring harness for a (whatever year you have) mustang. since you have the mach if your going to use the existing amps from that system youll need to do a few things, theres a sticky somewhere that tells you what you have to do to make em work. otherwise you will have no sound cuz the amps arent getting turned on.
any idea where the sticky might b located??? I have right now a pair of 10" pioneer subs wired into my amps but know that an aftermarket system will work a whole lot better and im just sick and tired of the 460 messing up and keeping my cd's
jwog666
Dec 27, 2021 08:09 PM
