HID Install Questions
Old Sep 17, 2007 | 03:35 PM
drifts14x's Avatar
drifts14x
Default HID Install Questions
Hey, for those of you who have HID's on your car, where did you tap into for power, and also, where did you mount your ballasts?
I have a 1995 GT with the battery still mounted under the hood and everything, so as I'm sure you know, space is not exactly abundant.
Also, what kind of wire connections did you use, because I need this setup to be basically permanent, I really hate doing the same job twice.
Old Sep 22, 2007 | 05:11 PM
drifts14x's Avatar
drifts14x
Default RE: HID Install Questions
Bump
Old Sep 23, 2007 | 12:00 AM
ttocs's Avatar
ttocs
Do not use anything less then soldering for connections. The high voltage for the ballast is very unforgiving when you make bad connections and leads to bad ballasts.
And for location stick your head under your bumper and look up at the fog lights. There is alot of space under there for you ballasts, just not for you head and hands...
As for wires they are all there, I would not go anywhere else....
Diode Dynamics
28
May 26, 2022 12:02 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
toastintx64
Aug 29, 2015 05:12 PM
Shifty Magoo
Aug 25, 2015 03:08 PM
inyadreems
Aug 21, 2015 09:10 AM
