fox ashtray switch
Old Oct 6, 2007 | 11:46 AM
jakeachy's Avatar
jakeachy
Default fox ashtray switch
well, thats what they look like.
fits well and a 20 second install.
anybody know what wire is 12v and ground?chilton doesnt know sh*t and i cant throw a lead tester on it.
Old Oct 6, 2007 | 04:14 PM
ttocs's Avatar
ttocs
Default RE: fox ashtray switch
the black wire that goes to the outside shield of the cig lighter is the ground, the wire that goes to the middle(looks blue and maybe white) is the constant. The blue and red is the dimmer wire, it will have 7-12v on it with the lights on. be sure to insulate it if your not using it or it will blow all your dash lights fuse.
Old Oct 6, 2007 | 04:55 PM
jakeachy's Avatar
jakeachy
would you reccomend the constant or dimmer?
Old Oct 7, 2007 | 09:42 PM
ttocs's Avatar
ttocs
the dimmer wire should not be used for anything except for lighting that you want to be switched with the parking lights. The constant should supply power for what you need but it will be on all the time.
Old Oct 7, 2007 | 09:51 PM
jakeachy's Avatar
jakeachy
ORIGINAL: ttocs
this is terrible coming from an installer( i never get time with anything but amp/sub installing) how can I make it on only when the car is on?
Old Oct 9, 2007 | 08:48 PM
DoctorD415's Avatar
DoctorD415
The last few times i've plugged in my radar detector to the cig lighter its blown a fuse (fuse for the horn, clock, and the light panel next to the clock telling me of the highbeams, low fuel ect.) on my 85 mustang GT. Why is it doing this, i dont really understand?
Old Oct 10, 2007 | 01:33 PM
ttocs's Avatar
ttocs
What is terrible? I answered your question as to what the wires were. If you didn't like the answer, then you didn't like yer question.
You are looking for a +12v switched wire. There should be one down there in the convertable hrns even if you don't have a vert. Otherwise you can look behind the radio or at the fuse box.
ORIGINAL: jakeachy
ORIGINAL: ttocs
Old Oct 10, 2007 | 01:34 PM
ttocs's Avatar
ttocs
Try unplugging the detector from the cord, then plugging just the cord in. We need to find out if there is a short in the cord or the unit. Start a new post and we can help ya.
ORIGINAL: DoctorD415
lincolnshibuya
Jul 5, 2020 03:05 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
guitarman376
Sep 30, 2015 05:54 PM
RCS02v6
Sep 29, 2015 01:46 PM
