amp wiring
Old Feb 22, 2005 | 12:46 PM
link1235jeff's Avatar
link1235jeff
Default amp wiring
should i run the positive amp wire and rca and remote wire next to each other or the positive wire and rca on oppisite sides
Old Feb 22, 2005 | 12:57 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: amp wiring
ideally on opposite sides... but its unlikely you could tell the difference either way
Old Feb 22, 2005 | 02:21 PM
link1235jeff
k
where should i ground it to
Old Feb 23, 2005 | 05:00 PM
demon_head's Avatar
demon_head
usually u should separate the positive and the rca, b/c u can pick up interference or a whinning sound sometimes if they're together. Just try and ground it to a good metal surface in the trunk or i've even seen people ground it under the back seat where the seat belts bolt into the metal body of the car. If the surface where u want to ground it at is painted, u might wanna sand/file the paint away so u get a good connection.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
